1995 R100Rt does it have solid or rubber diode board mounts?
Gian4
Post by Gian4 »
Hi all
Just bought a 1995 R100RT and wondering does this have solid or rubber mounted diode board?
Thanks
Gian4
robert
Re: 1995 R100Rt does it have solid or rubber diode board mou
Post by robert »
Find out here.---- http://www.maxbmwmotorcycles.com/fiche/fiche.aspx
Or look inside.
Post by Deleted User 62 »
Rubber, according to that fiche, and if you check, probably at least one broken. Now's the time to swap to solid mounts!
Last edited by Deleted User 62 on Tue Apr 23, 2013 1:04 pm, edited 2 times in total.
Snowbum suggests that the rubber mounts were used from about 1979 to about 1993. I had rubber mounts in my '78 R100/7, though.
Easy enough to check, though.
daz
Post by daz »
My 1995 R100RT Classic had rubber mounts.
1971 R50/5, 1980 R100T,
CRF 300 Rally, CRF 250F,
1947 James ML
Scoots
Post by Scoots »
I had to replace my rubber diode board mounts 3 years ago, shortly after I had acquired my '89 R100RS - PITA!!!
I recommend a pivoting head ratchet wrench (8mm if I recall correctly) to ease all the cuss words and a magnetic tool to retrieve all of the nuts that will jump to avoid your fingers!!!
Image Image
Image '89 R100RS Pearl White
