seat-pan progression
vanzen
Post by vanzen »
Building a seat-pan for the CRo. This is how it went ...
A Yamaha 125 TZ FRP repro piece by Air-Tech was chosen. The sub-frame was built to fit this pan:Image
A Dremel cut-off tool was used to revise the shape, the paint is rattle-can flat-camo.
A billet 40-LED tail light intended for the chopper market was lathe modified to fit it's fabricated alloy bracket. This assembly bolts to the sub-frame allowing seat-pan removal without disconnecting any wires:
Tractor tail light was in a box of items purchased at a farm auction:
The tractor stop-lens is secured to the seat-pan with silicone:
Thick-n-thin stripes, number graffix, and neoprene pads.
The neoprene was bought in a sheet, cut, carved, and sanded to shape.
Two screws remove the seat-pan from the sub-frame:
From the top:
Re: seat-pan progression
You are making headway......NICE!
Very unique work. I like it.
BUT, this is an Airhead site, right? You are still running a Nohead.
Post by Deleted User 287 »
Garnet wrote:You are making headway......NICE!
And it's almost winter! ;)
Soooo.... is that cross thread degridation..... or cross threaded contamination?
Nice bike, vanzen. Don't forget the fluids. :oops:
dwerbil
Moderator
Post by dwerbil »
And tightening drain plugs!
Click for pics
Randy in Round Rock
Post by Deleted User 62 »
Good Stuff! Did or will you have to dimple the tank for bars like that?
Ross
Post by Ross »
Great looking tail end there.
vanzen
dimples
Post by vanzen »
Tim Shepherd wrote:Good Stuff! Did or will you have to dimple the tank for bars like that?
Thanks Tim,
The tank has one dimple from a previous life mishap – a historical reference such as it is.
Clearance, lock to lock, is possible without any further hammering:
