I have decided to restore an r26 this year that I found in rough shape locally and need some help. I did an r60/6 last year which I ride daily. I will have al lot of questions in the next few months so here is the first ones. I am tearing down the engine and want to replace the piston rings. The one I have has four rings but the only ones available from Bmw are sets of three. Was this piston after market?
The valve guides also need replacing but Bmw lists a different part number for intake and exhaust. One is no longer available. However the valve stem diameters are the same. Are they different?
Any help will be appreciated.
Thanks
Lawrence
1958 r26 restoration
Re: 1958 r26 restoration
I had Vech overhaul my R25/2 engine last year. It was a stock piston with 4 rings. They reused one of the better old rings with a new 3-ring set. Probably pretty standard practice...or you could by two sets of rings.
As for valve guides, I don't really know. Vech sent my head off to Memphis Motor Werks.
When I rebuilt my engine I got everything from http://www.bmwbike.com/index.php?e=mhs in Switzerland. I used a new piston from an R50S which bumped the compression up over 9:1 with a nice increase in power. Another good source for parts is http://www.ulismotorradladen.de/uli/Web ... epage.aspx in Germany.
