gas soaked shoes
pmonk
gas soaked shoes
Post by pmonk »
Went for a little ride the other day. I was greatly enjoying how smoothe the R90/6 was running. Walked into the house and the wife says "YOU STINK". Mumbled something about yea I really need to replace the old mufflers because they are boogered up where they fit to the head pipes. She says "GETOUT OF THIS HOUSE NOW". Looking down I see my right sock seems to be discolored. Smells like gasoline, Shoes are soaked too. One of the things you have to enjoy about an airhead is dealing with leaking carbs from time to time. Hopefully it is just a little trash between needle and seat and not another set of ethanol ate up floats again.
Re: gas soaked shoes
I lost a float bowl and it coated the back wheel with gas, I hit a dew patch, and down I went.
pmonk
Post by pmonk »
ZM, I am fortunate, I got home with all my parts. Fuel can cause a slippery slope, especially diesel
Doubly fortunate. Mrs Pmonk told you to get out of the house. Go for another ride, after you've jiggled that float.
Slashsevenpig
Post by Slashsevenpig »
Don't forget to change your fuel lines. The rubber may be flaking from the inside. Ask me how I know.
I would suggest you resist the urge to dry your shoes and socks out in front of the fire....
jagarra
Post by jagarra »
The last time I had a bit of debris stuck in the needle and seat keeping the float open. I used my handy tire pump which was on board on my bike. Just unhooked the fuel line to the offending carb, put the hose against the hand pump and gave it a couple whacks of air. cleared it nicely without taking the bowls off.
gg
pmonk
Post by pmonk »
Replaced the float bowl gasket (which had obviously been leaking) and operated the float, needle and seat flushing it several times and put it back together hoping it would just be an easy fix. The gasoline flow did stop when the float was just about level. About to ride a while and do a final balance on the carbs after about a 30 minute ride. If this fixes it great, if not then it's time for new floats even though these aren't very old.
The think that is disgusting is how fast this government mandated ethanol containing slop we are forced to buy absorbs water. The float bowl was sitting about 2/3 full of clear gasoline. 10 minutes later it was so cloudy you could barely see the bottom of the bowl.
Bamboo812
Post by Bamboo812 »
I had problems with the cloudy gas, too. I don't know where you are located, but here is a listing of some of the ethanol free gas stations in the US and Canada. http://pure-gas.org/ Note: Don't toss those soaked floats just yet. When I switched back to e-free I had to re-adjust my floats because they began to float higher in the bowl causing fuel starvation at WOT. No problems at all now...
pmonk
Post by pmonk »
Very few stations located in my area on the Gulf Coast. I use Startron in my boat and will start adding to both my bikes. I couldn't believe how fast the clear gasoline turned milky. We are usually at 80% humidity or higher here along the coast.
The test ride didn't go so well. At about 4.5-5k the bike lost power, Glad I didn't start up over the bridge. Got home ok, pulled the bowl off and YIKES* Where is the main jet that I sprayed carb cleaner through. Found it in the tool tray of course. It ran fine at lower rpms though. So for now the leaking seems to have stopped and carbs are fairly close, close enough until time for valve adjustment anyway.
