Need a wiring diagram for a 1988 R100RT
Jeff in W.C.
Post by Jeff in W.C. »
Does anyone have a wiring diagram for a 1988 R100 RT. Don't answer just yet. BMW changed the main wiring harness in early 1991. The most current version of BMW's diagram CD shows the diagram as of August 1990, and references the newer wiring harness. One way to tell the two apart is that the older wiring harness has two fuses, while the newer one has four (one's not utilized). So I'm looking for the wiring diagram showing the older style wiring harness. I think that would be between late 1987 and August 1990, but I'm just taking a guess here with the dates.
Jeff in W.C.
1988 R100 RT
2018 R1200 GS
Re: Need a wiring diagram for a 1988 R100RT
Jeff in W.C.
Thanks for the link, but they have only one diagram for the 1987 -1995 RT's. While I haven't looked at it, there's a strong probability it's the diagram showing the newer diagram indicated in my original post.
I sent an email for clarification.
Jeff in W.C.
1988 R100 RT
2018 R1200 GS
Jeff, I have this one from the Haynes Manual.
It is labelled '1985-on R80 and R80RT, 1986-on R65m 1987-on R100RS and R100RT models'.
I don't have a scanner but have taken a pretty good hi-res photo (reduced here for posting). Send me an email and I'll attach it for you.
