Posts: 5036 Joined: Tue Aug 03, 2010 3:29 am
Post
by SteveD » Mon Nov 10, 2014 1:28 am
I have my finger behind these holes to help expose them better. They're pin hole size, but enough to allow oil out.
I've ordered a replacement and the 4 nuts for the shaft. In the meantime, is there a modern goop that might do the job sealing these for a while. I can rotate them to the top also.
Mal S7
Posts: 661 Joined: Thu Aug 05, 2010 5:26 am
Post
by Mal S7 » Mon Nov 10, 2014 1:30 am
If you can clean the area you could try a bicycle tube patch,
or, be brave and give it a light touch over with a soldering iron!
Posts: 3105 Joined: Thu Feb 13, 2014 2:05 am
Post
by Rob » Mon Nov 10, 2014 1:44 am
I would fashion a diaper and zip-tie it around the boot until the new one arrives.
Maybe?
Posts: 6008 Joined: Thu Aug 12, 2010 12:39 pm
Post
by Duane Ausherman » Mon Nov 10, 2014 2:23 am
I have seen Silicone stick in place on a hole on a U-joint boot.
Unless you are going a long distance, I wouldn't worry about it. The diaper is to keep things clean, but won't keep the oil in place. The oil level isn't important down to just under 1/2, or maybe less.
I have drained out 50 cc many times with no damage.
Justdan
Posts: 25 Joined: Sat Nov 01, 2014 3:25 am
Post
by Justdan » Mon Nov 10, 2014 3:39 am
Spooky. This what I was doing this afternoon.
Simple fix. Clean the oil out the holes and use a dab of super glue. The old super glue and clean rubber are made for each other.
Post
by SteveD » Mon Nov 10, 2014 4:20 am
That's what I was going to try Dan, but thought maybe a more recent goop might be better at it. I'll give it a shot tomorrow.
Duane, it's best to keep whatever oil is in there, as it seems to lubricate the rear wheel otherwise!
Posts: 7313 Joined: Tue Aug 03, 2010 3:00 am
Post
by ME 109 » Mon Nov 10, 2014 5:44 am
Duane Ausherman wrote: The diaper is to keep things clean, but won't keep the oil in place.
I'll second that.
Tried it with the kids, it didn't matter how well they were taped on, that shit still got out.
Posts: 2540 Joined: Wed Aug 04, 2010 6:19 pm
Post
by dougie » Mon Nov 10, 2014 9:08 am
grant81rs
Posts: 744 Joined: Tue Aug 03, 2010 2:06 am
Post
by grant81rs » Mon Nov 10, 2014 2:43 pm
Gidday,
Steve any plumbers type clear silicone, just slope it on it will work... or yes the old fav super glue!!
Cheers, Grant
Gippsland - Australia
1978 R100RS
1981 R100RS
1994 K1100RS
2005 R1150gsa
