Can anyone tell me when BMW started mounting the master cylinder on the handlebars? Thanks!
Tim
Master Cylinder
Re: Master Cylinder
From the 1981 models on...after September 1980.woodly1069 wrote:Can anyone tell me when BMW started mounting the master cylinder on the handlebars? Thanks!
Tim
http://www.maxbmwmotorcycles.com/fiche/PartsFiche.aspx
Trying to cross reference these dates from the usual parts fiche, looking under "brakes" the realoem and max fiche show the under tank setup, to 9/80.
You need to look at the "steering" section.
woodly1069
Re: Master Cylinder
fantastic! Thanks for the quick reply! The reason I ask is because I am chaning the original front end to something with a Nissin brake assembly and need to be able to activate it.
I have a 1978 R80 with the cable only coming out of the handlebar housing, is there a way to add this master cylinder to the existing assembly or do I just need to find the whole assembly with the master cylinder on the bars and eliminate the under tank master cylinder? Any advice is appreciated!
Tim
Tim
Re: Master Cylinder
Yep. It's not something that's never been done before. Usually best to source a 13mm mc from a monolever.woodly1069 wrote:.... I just need to find the whole assembly with the master cylinder on the bars and eliminate the under tank master cylinder.
http://www.advrider.com/forums/showthre ... 179&page=5
woodly1069
Re: Master Cylinder
Great! thanks for your help Steve!
Norm T R100T R1150RT
Re: Master Cylinder
Worth a look - http://www.amazon.com/gp/product/B001J8 ... C5XRRCX4P2
Norm Taylor
1980 R100T Airhead
2002 R1150RT Oilhead
1950 HD Panhead
Southern Maryland, USA
2003 K1200 GT
1980 R100T Airhead
1950 HD Panhead
2003 K1200 GT
