Rear mastercylinder
Motorhead
Rear mastercylinder
Post by Motorhead »
My Franken Beemer is down with a rear leaky master
most surches I conducted to how has not produced a kit to rebuild it
Another question is recently I picked up a late model final drive for Disc with no drum brake ability ( installed just before the leak
so does the early Non Drum brake final Have the same guts (gears)as the early drum brake case
If so I'd like just to install the guts (gears) into my empty final case I saved from my 1977 33/11
Re: Rear mastercylinder
Motorhead wrote: ..... I picked up a late model final drive for Disc with no drum brake ability ....
I can't see why they'd be different, but I'd go double check via the maxbmw fiche to be sure.
The biggest job you'll have is re-shimming the pinion to the crown. Many shy away from this task, so if you have a go, a few words and pictures would be fantastic.
chasbmw
Post by chasbmw »
Motobins sell rear M/C kits for £17 or £25 depending on age of bike. Their export service seems to work well
Charles
Motorhead
Post by Motorhead »
Well I don't know if the parts will fit as I checked Chas and although the drawing show no difference the parts number from the 1977 33/11 does not match the later part number from say the 1975 or match the later 1982
3 different years 3 different bikes 2 with a brake drum 1 with a disc and none of the number match
chasbmw
Post by chasbmw »
I think that '77 was the earliest year of the rear disc brake models, you could always ping 'Bins an email to ask........
Charles
Motorhead
Post by Motorhead »
Think I'll just go back to drums and look for the right rear drive
Personally, I really like the feel of drum rear brakes. Not the thing for the track, or even a hack or Goldwing on a steep 3000 ft. descent, but, for most riding, I like them better.
Motorhead
Post by Motorhead »
The best thing I can say is, as I rebuilt or modified! I found truth in my work, and nothing but trouble about how delivered
Meaning some parts came so used (woreout)and other parts needed rebuilding in deep levels (insterments and Pods)
New stuff into old stuff, a Fellow can build the bike easly enough if the arse bearing is not too tight and one not to scared to try... I was beatin when I could not afford the cost to keep orginal
Some prices too high but the Answer was better and cost less but made more work
When I got my other bike the stress on my BMW became not so much in the desire to prove the work on ATE or Brembo systems
Because after all I could buy the kit and do the work and find I'd really need a NEW MASTER CYLINDER because it was after rebuilding my under tank and the BMW kit failed to fix to find the Honda piston parts fit and worked......
replaceing my Mags going back to wire wheels
Any one want to buy my mags the rear wheel has the bolt on spline
Motorhead
Post by Motorhead »
also how many have done rebuilding the master whats the success or method OR am I taking a change like the under tank rebuild?
as I found BMW send the same piston size and no others are around if you know the bore of the master let me know maybe I'll be doin the Honda experamnt again........................
Motorhead
Post by Motorhead »
I have the rear wheel set back to wires and drum, I just might keep the front disc's
