I am currently playing with a '75 R90/6. I'm thinking of going to a handlebar master cylinder.
Is there any consensus on what size Mastercylinder to use with the 40mm ATE brakes
Motobins seem to stock a variety of sizes from 12mm to 16mm
Thanks Charles
Handle bar M/C size for 40MM ATE brakes
- George Ryals
Re: Handle bar M/C size for 40MM ATE brakes
Have you already tried the /6 (single disk) under tank MC with the (2) 40mm ATE's?
George,
I have not tried that option, but even over here good condition ATE M/Cs are not cheap.
Charles
Charles
- George Ryals
I thought maybe the '75 R90/6 had one.
If you are an agressive rider and like to rush the corners, brake hard and turn in, I would go for the 12 or 13 mm mc to give maximum hydraulic advantage. You will have a little more lever travel than with a 15 or 16 mm mc.
well thats not true
my undetank 13mm is a stopper and my lever does this with no extra work or lever work
all action to lock up is under 1" of travel
Could be the Honda pistion that still working, I used over the german one that leaked
I still have my original MC that came with the single brake. Are you saying that using that one will give me more brake than the one for the two brakes?George Ryals wrote:Have you already tried the /6 (single disk) under tank MC with the (2) 40mm ATE's?
Yes.Chuey wrote:I still have my original MC that came with the single brake. Are you saying that using that one will give me more brake than the one for the two brakes?George Ryals wrote:Have you already tried the /6 (single disk) under tank MC with the (2) 40mm ATE's?
Hydraulics are based on the ratio between the surface area of the master cylinder piston, and the surface area of the slave pistons. A M/C that has a poor ratio with the single caliper, will have twice the mechanical advantage with two of those calipers. In a well designed brake system, doubling the slave area would lead to a ridiculously sensitive brake, but, since the original BMW ATE brakes were rather anemic and wooden, it's possible that the crappy ratio with the stock M/C and one caliper might be quite effective with two calipers.
with my first BMW I found with the 38mm, I had like was said two wooden blocks
but as the stock hose was rotten, I replaced with steel braded that went a long way and changed the stock for a set of aftermarket maybe a SBS or Metal splinter pads
and I got a better working disc, later with my Second BMW when I tried the same set up but with a 40mm, I felt who needs a second disc with such a nice brake.... But then I found the pieces to go to mags and a second disc with a second 40mm I could't look back
- Ken in Oklahoma
Source for master cylinder?
So, where should Charles go to buy his master cylinder when he figues out what size he wants?
(Sly way to ask my question without bending Charles' topic. It's time for me to upgrade the brakes on my '76 R75/6)
- Max Headroom
Chas, I used a 13mm h/b unit for my bike. It has 40mm Ate calipers too. I'm very happy with the brakes.chasbmw wrote:I am currently playing with a '75 R90/6. I'm thinking of going to a handlebar master cylinder.
Thanks Charles
P.S.
Henry says hello!
- Mark Twain
- Mark Twain
