Which years had the tachometer with the blue high beam indicator light at about 6 o'clock?
The 81-84 had the high beam light under the GEN light in the middle of the housing, so it's some models before that.
Instrument housing model ID.
Re: Instrument housing model ID.
My 1975 R75/6 has the high beam indicator in the 6 o'clock position on the tachometer.
Thanks Melville. I'm presuming therefore that the whole /7 range also used it.
Roger that SteveThanks Melville. I'm presuming therefore that the whole /7 range also used it.
R100RS to R100S Conversion
My (Jim's now) 74 R75/6 has bright indicator in 6 position.
