Gearbox R100CS replace R100RT Possible???
Wern2be
Post by Wern2be »
Hozit Gents,
I have a BMW R100RT boxer motor but without a gearbox. I do have a complete gearbox from a R100CS will this work on the RT and can I do a straight swop? Please can you help with this.
Thank you
chasbmw
Re: Gearbox R100CS replace R100RT Possible???
Post by chasbmw »
The gearboxes from the light fly wheeled bikes produced in the 1982 and later model years will not fit the earlier bikes without modification, the input shaft of the gearbox is a different length and the clutch actuation mechanism is different.
Charles
The new clutch carrier/flywheel combos and transmissions started with the 1981 models.
PAS
Post by PAS »
Kurt is correct. 1981 is the conversion year.
Wern2be
Post by Wern2be »
Thank you gents
