The bike started fine, some minor adjustment to the dellortos and ignition en than this weekeind it was time for a small test drive.
when I got to the first corner to the right and put out my turning signal a strange loud noise appeared. Stopped immediately because id did not sound good. It only happens when the turning signal to the right is on. Went home and looked into it.
When I use the turning signal to the left nothing strange happens, just the light go on and off, like the should. To the right, the starter motor starts to run
When I pull the turning relais, there is no problem, it seem there is a connection between the turning signal and the starter motor?
Does anyone have an idea what could be wrong? please help, electrics is not my strongpoint.
Got the right schedule i think, it is a "79 R100RS
https://www.dropbox.com/s/aki0ay6j6d2tq ... 9.pdf?dl=0
