How to deal with oxidation on engine cases?
drcollie
Post by drcollie »
Any tips on how to make this look better without removing the engine from the frame and getting into media blasting, etc.
19 73 R75/5. Thanks! Duane
Re: How to deal with oxidation on engine cases?
I think you can soda blast in-frame.
Major Softie wrote:I think you can soda blast in-frame.
In a paddock somewhere...it can get messy.
https://www.youtube.com/watch?v=KULVhW2tw4I
Mal S7
Post by Mal S7 »
You can get a lot of it with elbow grease, scotchbrite (brillo?) pads and wire brushes and WD-40. Remove the front and top covers, the clam-shells and clean them on a bench, easy!
Takes some time, just do it every time you wash it and in just a few years ...
In between the fins is a real bastard, you may need to get that blasted.
Post by Rob »
My heads looked SO PRETTY (like brand new!) when they returned from Bob Grauer when he did the valves for me. :ugeek:
I've done a bit of that. The process I used is described toward the end of the first page:
viewtopic.php?f=1&t=148
I did have the motor and trans out of the frame, but it should be doable in the frame as well. Not necessary to blast the cylinders.
I live in a place with a corrosive atmosphere, within sight of the ocean and high humidity year round. I have to spend a couple hours every spring with a ScotchBrite pad to keep it fresh.
Post by Rob »
melville wrote:I've done a bit of that. The process I used is described toward the end of the first page:
gspd!!!
(an old, long not-posted member, Duane. He taught melville everything he knows about brightening! That link is a good one to study!)
I'd move to Albury, NSW, Australia. Or Bethanga!
No corrosion here.
2valve
Post by 2valve »
Have a go at using the liquid type of mag wheel cleaner with a stiff nylon brush.I use a brand called Kitten ,really safe to use. Make sure that the part you're cleaning is really wet with the cleaner and start scrubbing. Just make sure that you have you're garden hose ready for clean up time.Worked for me.
On the cases, you can clean with aluminum wheel cleaner, then spray with aluminum color engine/exhaust paint and before the paint dries, scrub it into the pores of the engine with a Scotchbrite abrasive pad. It sounds kind of corny and unsophisticated but it does work and you can kind of make your own procedure for how nutso you want to go with it.
