Bamboo812 wrote:Try bleeding it without the vacuum pump. They suck air into the system. Just; pump, hold, bleed and repeat. Some here have mentioned wrapping a bunji cord around the lever overnight, as a method to get the last bit of air out of the system.
Vacuum pumps do not suck air "into the system." Where would that air come from, and how would it get in? Any leak that allowed air to be sucked in would spew huge amounts of fluid at braking pressures.
What vacuum pumps DO do is suck air into the the tube that is attached to the bleeder valve
downstream of the system, so you can't tell if you're still getting air out of the system or if you're just seeing air that has been sucked in at the bleeder.
I haven't used the speed bleeder valves, so it may not be a problem with those, but with regular bleeders I have found that I have to wrap the threads with Teflon tape to keep air from being sucked past the threads. This does not impact the seal of the bleeder as that seal is created by the cone shaped end of the bleeder forced into the caliper - metal on metal, but you have to make sure you do not allow any of the tape to get down there on the end - only on the threads.
The overnight handle squeeze is definitely the best way to get any air trapped at the top of the system in the Master Cylinder. I've found that no matter how well I bleed a system, that last step makes a difference. Once after bleeding and then one more night after riding usually makes an even bigger difference.
