How to tell clutch wear?
Posted: Tue Feb 02, 2016 12:21 am
by jjwithers
I have about 4 or 5 used clutch assemblies sitting around. Some are /5, others are /6.
I'm putting together a R75/5 mostly from spare parts and trying not to spend money if I don't have to.
How can you tell how much life is left on a clutch? Can you gauge the thickness of the pressure plate?
If so, what is a good vs worn amount?
Or is it the general surface of the pressure plate being worn somehow?
Is it safe to reuse the spring, pressure plate and compression ring?
-josh
Re: How to tell clutch wear?
Posted: Tue Feb 02, 2016 1:29 am
by Bamboo812
Duane's got you covered there: http://w6rec.com/duane/bmw/clutch/
Posted: Tue Feb 02, 2016 5:47 am
by equipo5
Just received my new clutch spring for my R75 from Motorworks today. It is 1mm higher (18.5mm) than my old failing spring (17.5mm).
I couldnt measure the pressure and cover plates but from Duanes site I gather the smoother the more contact area.
cheers
Posted: Tue Feb 02, 2016 10:27 am
by jagarra
If you measure the disc thickness the minimum is 4.5mm.
Posted: Tue Feb 02, 2016 10:46 am
by jjwithers
Douph! I should have checked Duane's site first.
Thanks for the helpful info and measurements.
-Jj
Posted: Wed Feb 03, 2016 7:54 am
by PAS
I would put a straight edge across the pressure plate to see how flat it is.
