1975 R90/6 How to lower suspension? ?
So I am short 5'6" and wanted to lower the height of the bike to allow both feet to be flat on ground when stopped. I want to replace rear shocks and rebuild front. What are the ways of lowering and where are you guys buying your parts. Also plan to cafe the bike.
- Airbear
Re: 1975 R90/6 How to lower suspension? ?
G'day shorty Patdabin, and welcome aboard. I'm 1.5 inches shorter than you, and found that a lower seat allows me to get both feet flat on the ground. It feels much safer when maneuvering in a carpark.
If you are going the cafe route a lower and flatter seat is normally a requirement, so save yourself some trouble and keep the stock suspension.
If you can find some tires with a smaller aspect ratio, you can lower bike another quarter inch or so.
Wookie
Wookie
Assuming no maximum loads; I would get 13" rear shocks, same as the short wheelbase bikes, and a aftermarket top clamp that allows the fork to be slid up a bit higher... los dos centavos
Thank you to everyone for the replies.
Where are you getting your parts?
The top clamp you talk of do you have a recommendation for a place to get one. Link perhaps.Bamboo812 wrote:Assuming no maximum loads; I would get 13" rear shocks, same as the short wheelbase bikes, and a aftermarket top clamp that allows the fork to be slid up a bit higher... los dos centavos
- Airbear
Is there a post on this forum that has links to places to shop parts.
From Cleveland?Patdabin wrote:Is there a post on this forum that has links to places to shop parts.
Florida...there's http://www.bmwhucky.com/
He gets good review from NA airheads.
Us lot use www.motobins.co.uk quite a bit.
Then there's ebay, craigs list, ibmwr...there must be some recyclers too.
How did you know I'm from Cleveland?SteveD wrote:From Cleveland?Patdabin wrote:Is there a post on this forum that has links to places to shop parts.
Us lot use http://www.motobins.co.uk quite a bit.
