Dellorto R90 Carbs with frozen slides
jjwithers
Re: Dellorto R90 Carbs with frozen slides
Post by jjwithers »
I have an ultrasonic cleaner which should fit a whole carb in it. I am afraid of damaging it with petrol based chemicals though.
I think I'll try to the ATF / Acetone trick. Do you just soak the carbs in a bucket of that stuff and see what happens?
Texer - these are my first DellOrtos. I'd love a copy too.
www.beemersandbits.com
'66 R60/2
'72 BMW 2002
Instagram - jj_withers
Bamboo812
Post by Bamboo812 »
Josh, I use about a 20% mix of Simple Green and hot tap water in my ultrasonic cleaner with very good results. No toxic fumes!
2valve
Post by 2valve »
i Wouldn't think that petrol based cleaners should harm them.They are designed to be fuel wet /fuel vapours etc.
jjwithers
Post by jjwithers »
I use simple green, laundry detergent and other soaps in my ultrasonic cleaner. I read somewhere in the manual to avoid flammable fluids though. Mine is probably meant more for medical devices vs motorcycle parts... but so be it.
When people do the ATF mix, is it done in a bucket or ??
'66 R60/2
'72 BMW 2002
jagarra
Post by jagarra »
Be careful how long you leave the carburetor body in your ultrasonic cleaner. When I did the carburetor on one of my cars using just dish soap and water for an extended period it took the finish off the body. I have had it take Parkerizing off firearm parts.
1974 R90/6 built 9/73
1987 BMW K75S
1994 BMW R1100RS
1964 T100SR Triumph
1986 Honda XL600R
jagarra wrote:Be careful how long you leave the carburetor body in your ultrasonic cleaner. When I did the carburetor on one of my cars using just dish soap and water for an extended period it took the finish off the body. I have had it take Parkerizing off firearm parts.
Wow, I never would have imagined - especially about taking Parkerizing off.
jagarra
Post by jagarra »
I left a bunch of NOS M1 carbine bolts in there over night, took some of the finish off them. I guess it was some bad vibes.
1987 BMW K75S
1994 BMW R1100RS
1964 T100SR Triumph
1986 Honda XL600R
Nyuck Nyuck
Texer
Post by Texer »
JJ and 2valve, I just made a pdf of the Dellorto guide. What's the best way to get this to you?
1970 R75/5
1974 R90s
jjwithers
Post by jjwithers »
I just emailed you through the forum... and thanks!
Texer wrote:JJ and 2valve, I just made a pdf of the Dellorto guide. What's the best way to get this to you?
'66 R60/2
'72 BMW 2002
