Is there a consensus how often this should be done? I did mine with moly about 20K miles ago. Do I need to take this apart now?
No, basically.Zombie Master wrote: Do I need to take this apart now?
10 years.enigmaT120 wrote:I did one first because the bike was new to me. Then I had the gearbox go out, so did it when I put everything back together. Then my clutch went out, so I did it again. Then last year that stupid pawl spring broke, so I had to pull the gearbox again and replace that. I've been lubing mine way more often than 20,000 miles, I think... The splines always looks OK, though.
How long ago was 20,000 miles?
Try harder.Duane Ausherman wrote:The lube sort of dries out and doesn't do my lubing after some time.
