Throttle lock /cruise control for an R80 ?
Sibbo
Post by Sibbo »
About 5 years ago i chopped off my right thumb ...a mistake I'm told ! :D I had it reattached but all is not perfect .I get cramps in my right hand that I didn't used to get ,sometimes it goes numb from having to maintain a fixed position ,as it does on a long ride .
Does anyone know of a throttle lock that i could fit or fabricate, something that would allow me to just rest my hand on top of the grip for a while while riding ?
The Grateful Dead
Re: Throttle lock /cruise control for an R80 ?
You might have one already. Have a look under the throttle housing for a large screw in bolt. Otherwise, there is a covered recess there for the bolt.
Ross
Post by Ross »
This is what I use.
Unclviny
Post by Unclviny »
I was looking at a "Crampbuster" today, it just slips onto the grip and you use your palm on it.
Vince
1973-1/2 BMW R75/5 (LWB)
1971 Norton Commando
1952 Triumph TRW
1936 BMW R2
I have the throttle lock screw in Steve's pic below. They work very well and the throttle can still be used almost normally.
I don't have an American coin like Steve has tho' :(
Ross
Post by Ross »
Munich Motorcycles has them Image for $18.
The Throttle Rocker I use allows me to control the throttle without having to always have my hand wrapped around the twist grip. So in other words my hand is flat and I can still open and close the throttle. Great for long distances.
I do have a throttle stop screw fitted. I use it when i warm the bike up on cold start ups. Lock the throttle just off idle. This helps as I only run one choke. I find with the throttle screw that I can not use it when I have a tank bag fitted as I have to reach over with my other hand to tighten it.
FUTURE wrote:Munich Motorcycles has them Image for $18.
Mine is left on all the time.
Ross
Post by Ross »
So this would mean that you ride with it screwed in so that you have to push the throttle closed by hand???
Sibbo
Post by Sibbo »
FUTURE wrote:This is what I use.
I have one of those and it is good ,although it seems to need constant adjustment .
That screw looks great ! I just checked Tilly and there is a nice hole where there should be a bolt . :roll: I'll ring Munich ,it looks as though it might be worth $18 .
Thanks fellas !
The Grateful Dead
Sibbo
Post by Sibbo »
I just ordered one ...I'll adjust it to just slightly reduce the return tension ...does that sound OK ?
$18 ..$23.45 posted .
The Grateful Dead
