BMW has a better idea!
Unclviny
Post by Unclviny »
Allright, who is the wiseass that is making me remove the ENTIRE exhaust system to change the centerstand?, the Germans must still be mad about the War and this is payback!
Vince
1973-1/2 BMW R75/5 (LWB)
1971 Norton Commando
1952 Triumph TRW
1936 BMW R2
dwerbil
Moderator
Re: BMW has a better idea!
Post by dwerbil »
Unclviny wrote:Allright, who is the wiseass that is making me remove the ENTIRE exhaust system to change the centerstand?, the Germans must still be mad about the War and this is payback!
Vince
Now you get to deal with the crapola centerstand bolt set up.
Click for pics
Randy in Round Rock
barndeadr80
Post by barndeadr80 »
A plot to make you destroy the threads on the exhausts on your heads? To make you buy new heads? To find a cylinder stud is stripped in the block? etc
barndeadr80 wrote:A plot to make you destroy the threads on the exhausts on your heads? To make you buy new heads? To find a cylinder stud is stripped in the block? etc
And while you're there, how are the rod bearings?
If it makes you feel any better, I had to remove the ENTIRE center AND side-stand assembly to change the exhaust on my Oilhead.
Okay, I know, it didn't make you feel any better...
Post by Deleted User 62 »
Of course you'll want to change the main seal, just to be sure, and... and... hey how did I end up with a bare frame surrounded by parts? :shock: Oh well, might as well paint it while everything is off.
I have to remove my entire exhaust system to change my oil filter. Stupid rear balance pipe!
Unclviny
Post by Unclviny »
Tomorrow is "centerstand day", I got the widened, stock-unit with 2 extra feet on it so it should not be "tippy" anymore (with new bolts, bushings and washers standing-by).
Today's deal was installing the new connector in the headlight bucket and swapping to LED turn signals, I had about 90% success. The bike runs (always a good sign) but regardless of which turn I signal for all 4 turn signals flash!, so I closed up the garage for the night (it's Rum and coke and a schematic for me tonight).
Vince
1952 Triumph TRW
1936 BMW R2
Jeff in W.C.
Post by Jeff in W.C. »
Vince
How about needing to remove the engine--or at least the oil pan to remove the side stand. The local guru's here say the motor needs to come out. :evil: No wonder why very few people ever service the side stand.
Jeff in W.C.
1988 R100 RT
2018 R1200 GS
Roy Gavin
Post by Roy Gavin »
My G/S has a sump extension, so that has to come off too.
I just fitted a Brown side stand to my R75/7 - if anyone knows how to remove the OEM stand without removing the engine or using an angle grinder let us know!
