Broken Horn Mounting Brackets
bigfella
Post by bigfella »
Hi fellows, I'm in the process of stripping my /7 and have found the horn mounting brackets broken on both sides of the frame. They look like a vibration related stress fracture.
Has anyone else seen similar damage on their frames?
I'll make new tags a little stronger and weld them in place when I strip and blast the frame, i'm just interested to know if it is normal damage, that is all.
cheers, Sam
Why is the rum always gone? - Capt. J. Sparrow.
Re: Broken Horn Mounting Brackets
Gidday Sam, I can't remember the fine print, but there's method in the madness with the horn brackets.
Two thin strips isn't it?
It helps with the sound of the horn apparently.
Going to a thicker strip (like 3mm) will affect sound.
CVA-42
Post by CVA-42 »
Similar experience with the horn brackets on my '82 R100 some years ago. I fabricated new ones from thicker stock. Don't remember if there was a change in the sound of the horns or not.
I just removed a horn from a 1974 R90/6 yesterday in preparation for shipping it out. Yes, it had two thin springy strips of metal for vibration.
Guess it will go on eBay along with all the rest.
jjwithers
Post by jjwithers »
Definitely normal. Unfortunately too.
After about 10,000 miles of a complete restoration of my R100S, one of the horn brackets broke.
www.beemersandbits.com
'66 R60/2
'72 BMW 2002
Instagram - jj_withers
Ray from Indiana
Post by Ray from Indiana »
I didn't like the wimpy horn on my 82 R100 so I installed a Nautilus horn. When a horn is needed its just the ticket - it really gets their attention.
I used a piece of 1/8" x 1" x 6" strap metal, drilled it, painted it black and mounted as shown below.
Nuttin like twin oe fiamms :o
ME 109 wrote:Nuttin like twin oe fiamms :o
Makes people think they've just tried to lane change right through a Cadillac.
Post by Deleted User 287 »
OP - are you talking about two brackets on the outside of each leg of the main frame?
I remember seeing those in ads and in the showroom before I bought my R65. I was really disappointed in the single disk-type horn.
So I fixed it.
Anyway, those side horn mounts may be similar to the coil mounts on the early R65 - that being a 'U' shaped bracket welded to the main frame. On the R65 the coils were mounted to them, along with the main ground on the front coil. When the coil mount eventually broke (those that got ridden broke) it removed the ground connector from the circuit!
Anyway, that is what I think the OP is talking about. In which case, you will need to fab some new brackets and weld them to the frame - or do something entirely different...
montmil
Post by montmil »
Got my twin Fiamms at Auto Zone. Mounted 'em up on the '81 R65 just like 'oneoftheRobguys' using two thin straps for each horn. The Major is correct about dualies...
Them muthas are loud. Best function is with a horn relay added to the wiring harness.
1981 R65
1983 R65
1978 R100S
1995 Triumph Trophy
