Thanks to SteveD in Melbourne, Oz
SteveD, I used the caliper up brake fluid injection method you described in one of your posts after I installed new handlebars and brake lines. I had a totally empty system and it worked a treat. Filled the left side first then listened to the bubbles as I did the right side. Good firm lever and not a bubble in sight on the first try. Thanks
- Moderator
Re: Thanks to SteveD in Melbourne, Oz
Does this place rock or what!
Steve's the 'brake man'.dwerbil wrote:Does this place rock or what!
I'll be looking up his great caliper rebuild thread before long.
I effed it up the first few times I tried it, but now that I get ittimkil wrote:SteveD, I used the caliper up brake fluid injection method you described in one of your posts after I installed new handlebars and brake lines. I had a totally empty system and it worked a treat. Filled the left side first then listened to the bubbles as I did the right side. Good firm lever and not a bubble in sight on the first try. Thanks
1974 R90/6 ::Thor::
I should also say thanks to Moosehead for the brake line information. You guys rock and roll.
