I should have added that in my post.SteveD wrote: Mine is left on all the time.
Throttle lock /cruise control for an R80 ?
Re: Throttle lock /cruise control for an R80 ?
Push bike inner tube cut and fitted to the twist grip stops mine from moving.Sibbo wrote:FUTURE wrote:This is what I use.
I have one of those and it is good ,although it seems to need constant adjustment .
That screw looks great ! I just checked Tilly and there is a nice hole where there should be a bolt .I'll ring Munich ,it looks as though it might be worth $18 .
Thanks fellas !
- Sibbo
Yep ,I've done that ...i even glued a bit of 120 g sandpaper to the inside face .It always seems to gradually slip around .
The Grateful Dead
The Grateful Dead
A combination of the factory throttle screw and lighter weight carb springs was what I needed. With the lighter springs, I was able to back off on the drag from the throttle screw. Much more pleasant and easier to maintain speed.
I have one of Bill Schneider's Flip-a-Lever Throttle Control thingys. It works like the factory friction lock, except it can be locked and unlocked with a lever. Sorry I don't have a picture. Its dark outside. Anyway, it is a simple and functional device, but evidently is not available anymore.
http://www.bmwmoa.org/forum/showthread.php?t=32266
Bummer
Bummer
1975 R90/6
1979 R65
1979 R65
Thats the one that I run. I must have bought one of the last ones then.bbelk wrote:I have one of Bill Schneider's Flip-a-Lever Throttle Control thingys. It works like the factory friction lock, except it can be locked and unlocked with a lever. Sorry I don't have a picture. Its dark outside. Anyway, it is a simple and functional device, but evidently is not available anymore.
Bummer
A friend uses his g/f's scrunchy wrapped b/w the thottle grip and the housing.
Then there's this thing too.
http://www.2wheelride.com/throttle_pro.html
I've heard of people using an O-ring in the same way. The disadvantage for both is that you can't easily "turn it off."SteveD wrote:A friend uses his g/f's scrunchy wrapped b/w the thottle grip and the housing.
- Sibbo
Hmmm , 5 minutes on the bandsaw would make one of those .I have a bit of 1/2'' HDPE lying around ,black even !
![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
The Grateful Dead
The Grateful Dead
instead of the screw, how about the old flip-a-lever. they seem to be out of business, but you'll find them on ebay
http://cgi.ebay.com/ebaymotors/Motorcyc ... 4aa8104f29
i have them on all my airheads. they allow you to easily turn them off when you want.
